HELP! Carb CLogged?
Old Mar 3, 2012 | 10:00 AM
davethebrave's Avatar
Default HELP! Carb CLogged?
Hey everyone, so i got a AC 08 366 that wont start. has spark, clean air filter, gas, new oil and filter, new spark plug, and new battery. i put a lil gas on the plug yesterday and a shot of gas in the hole, than hit the ignition and it fired up for bout 2-3 seconds. this mean the engine isnt gettin gas and the carbs is clogged? thanks!
Old Mar 3, 2012 | 10:12 AM
Jaster94's Avatar
fuel delivery issue....yes. do you have fuel past the fuel filter and through the petcock valve? does the float bowl have fuel (checked through the bowl drain)? if you have fuel up to the bowl, then yes, you're up to the float/needle valve and jets. have fun!
Old Mar 3, 2012 | 10:17 AM
yeah when i put the tank on reserve, gas pours out the hose. I bet one of the needles is clogged, or the float is stuck most likely. just wanted to make sure!!!! thanks!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
