150cc quad dingo PROBLEMS
Old Oct 30, 2012 | 05:13 PM
Crazzycajun89's Avatar
Default 150cc quad dingo PROBLEMS
i got a dingo for free not exactly free cleaned out a garage an was tole to take it as payment so hey i jumped on it in a heart beat well its was fine except it need a wire retired back into the harnessbut onto my problem a lil brother dumped oil an gas into the tank thinking it would run just fine an go well it gummed everything up i tore apart the carb an its clean an not i dont rememeber the adjmusments on the needle in the bottom of the carb an the adjusment on the side of the carb, an on top of it all it has lpressure in the oil ,so when i got to check the oil it spiits oil at me WHat the hell do i need todo besides junk it any help be great thanks
Old Oct 31, 2012 | 06:21 AM
Jaster94's Avatar
read the carb sticky note in the forum for carb adjustments. as far as spitting oil at you........, don't know, you didn't give enough information as to when, where, how, what it is doing, etc.....kind of hard to make out what you're saying or trying to imply or relay to us. yeah, i from the south too, but make it understandable.
Old Oct 31, 2012 | 11:47 AM
Sorry bout that chief iwas rahter pissed off at the damn lil thing but as for the oil it is spitting it out where the dipstick goes on the bottom of the engine the lil neck it screws into its got pressure behind it , in other words when i unscrew the dipstick an turn it over it spits oil out an when i close it back up an start it an runs for a few seconds an then unscrew it it spits **** everywhere Lil better? An thnaks for the sticky note
Old Nov 1, 2012 | 06:18 AM
Jaster94's Avatar
yeah, sorry, i was in a rotten mood also. i apologize myself. anyways, what condition is the spark plug in? is it oily? please pull the spark plug and do a compression check. use a gauge and not your thumb. how many psig (pounds per square inch gauged) does it show? put the the gauge in and crank it and watch the gauge. it may have some blowby from the rings. but the pressure test will help determine that.
moneyman01
Jul 11, 2015 08:50 PM
DTroyer01
Jul 3, 2015 07:34 AM
JackTheKing
Jun 14, 2015 03:04 PM
Jaster94
3) General Discussions..
May 29, 2015 08:45 AM
elmer119
May 24, 2015 10:51 AM
