What are plow skids for?
Old Jan 10, 2014 | 09:27 PM
keithert's Avatar
Default What are plow skids for?
My Cycle Country plow lost one of its skids and the other got bent so I took them off. What are the skids for and what is the effect of not having them installed? Below is a picture of the type of skid it came with. I just found them on Amazon and have ordered a new pair. A friend of mine says he has never used them and the plow works better without them.
Old Jan 10, 2014 | 10:45 PM
user493's Avatar
Moto Psycho
If you plow on cement like I do the blade wears down too fast without skids on it. I think that on dirt or gravel they're supposed to keep the blade from digging in too deep.
Old Jan 11, 2014 | 08:14 AM
John32070's Avatar
I just took mine off too (one broke off actually). I'm not plowing on gravel much anymore since I moved to town from the country and that's the only reason I saw for them, but usually ground is so uneven anyway you're still getting a little deep even with them on. I just keep my finger on the button to raise if I sense I need to.
Old Jan 11, 2014 | 10:12 AM
As mentioned above you adjust them to keep the blade at just the right height to scrape whatever surface you're plowing without the blade getting too worn. Kind of an extra to the wear bar that makes contact with the surface.
Old Jan 11, 2014 | 03:21 PM
user493's Avatar
Moto Psycho
When I first got my plow I adjusted the skids so they weren't quite touching the ground. When I plowed the wear bar wore down just a little bit so everything fit perfectly when the skids did hit.
Old Jan 12, 2014 | 09:30 AM
keithert's Avatar
Thanks for the replies. I'll use the new ones just to avoid wear on the plow blade.
Old Jan 13, 2014 | 05:02 AM
mudslinginfool's Avatar
Does it in the Mud!
I let mine run on the blade. it took mine around 5 years to wear to the point the blade needed replaced and at that point it was cheaper to buy the $15 steel piece (1"x 60") i needed from home depot and welded straight to the old blade rather than order new skidders that ended up breaking off and were a pain in the first place. They cost more too,at least the ones i found. The blade doesnt wear that fast, the skidders are only touching in about a 1.5-2 maybe 3" surface area,each ,so about 3"-6" of surface area,the blade is 50-60" long. much more surface area so it takes a while to wear down. it doesnt mark the drive way either.
Old Jan 14, 2014 | 02:25 PM
jgar's Avatar
We pull them off all of the plows and chuck em. All you have to do is keep a good cutting edge on the blade.
Like others have said if your cutting edge is spent the skids will keep your plow blade from getting worn.
Alex G.
Sep 11, 2017 11:38 PM
shimanok2
Jan 29, 2016 07:37 PM
Oct 10, 2015 10:20 AM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
