Need help wont start
Old Dec 8, 2014 | 06:26 AM
Countryboy_David's Avatar
Default Need help wont start
I just bought a 1989 moto4 worrior 350 the guy I bought it from had a litype exhaust that broke off and rode it like that for awhile so I bought it off of him rode it then I was getting low on gas got some from a friend before I could get home I notice it started backfiring and I geared it down and got into it it bogged and cut off now I can't get it started all it does is pop and backfire once in awhile it'll blow constant fire out the exhaust im hopping it aint a burnt valve
Last edited by Countryboy_David; Dec 8, 2014 at 06:27 AM. Reason: Bought a 1989 moto4 350 worrior wont start
Old Dec 8, 2014 | 12:28 PM
brumbear's Avatar
check compression it's more than probably something simple change the plug look at the old one it will tell you a story if you look right
Old Dec 8, 2014 | 12:30 PM
Ya I already changed the spark plug same results like it's wanting to start but it ain't
Old Dec 9, 2014 | 06:11 AM
brumbear's Avatar
You have a fuel issue most probably if there is no compression it may be bigger issue but pull your plug out check compression.Check for spark as well,
If you have compr. and spark the problem is FUEl
Old Dec 9, 2014 | 06:15 AM
It has compression and spark everyone I talked to says it's a burnt valve
Old Dec 9, 2014 | 04:50 PM
Have you checked valve clearance? May be all it is. If that doesn't help then you can do a leak down test and it will show you real quick if the valves are leaking,plus you can hear air hiss from either the carb or exhaust.If it's leaking more than 25% then it's good enough reason to tear the head off and check things out.
Old Dec 9, 2014 | 05:23 PM
I think it has something to do with the heads
Old Dec 9, 2014 | 06:14 PM
DGNAZ's Avatar
How much compression does it have? Burnt valves usually cause low compression.
Have you checked for fuel flow? When you get "low on gas" is usually when all the trash gets sucked in the carb. That's really what this sounds like.
I'm not sure i understood...but if you said the exhaust was real short, then i probably will blow fire out of it.
Old Dec 9, 2014 | 06:17 PM
Oooo ya lots of fire haha
Old Dec 9, 2014 | 06:18 PM
So one kik me GoBugs956 so I can send pics of the bike and stuff
