Phoenix Polaris 200 electrical /no power problem
Old May 4, 2015 | 10:12 AM
EJM's Avatar
EJM
Default Phoenix Polaris 200 electrical /no power problem
Hello All,
I have a 2006 Phoenix Polaris 200 that I am having some issues starting. The strange part is it only happens once in a while and when it’s started it works great! I noticed there is no power when I am having the problem starting it. It almost seems like it is temperamental. I changed the fuse once and I think it worked or I may have just been lucky because the next day I went to start it and I had the same problem. I let it sit for a few hours and then it would start up to my surprise once again.
If anyone knows how to fix this electrical /no power problem it would be greatly appreciated! Also is it possible to kick start the bike if there is no power, I tried a few time and it would not start?
Old May 4, 2015 | 10:40 AM
Start at the battery first. Make sure connections are tight and if you have any reason to suspect the battery,even if it's a new one,have it load tested..Plus once running check that you have 13-14 volts or so going back into the battery while at an idle.If not,then could be a faulty regulator not keeping the battery charged.
Old May 4, 2015 | 10:50 AM
EJM's Avatar
EJM
Thank you for the reply... It's not the battery I have two Phoenix Polaris and I switched the batteries and still had the same problem with the one ATV.
ripperray
Oct 10, 2023 02:42 AM
txkevin
Sep 21, 2015 02:02 PM
TJM
Jun 11, 2015 01:28 PM
Jun 10, 2015 11:20 PM
kencbs
May 23, 2015 05:29 PM
