Hoping someone could help me out 2006 kfx80
Old Jul 25, 2015 | 08:48 PM
Mikesohio's Avatar
Default Hoping someone could help me out 2006 kfx80
New to the forum, and to working on ATVs. I purchased a kfx80 for my 7 year old boy and 6 year old girl. Runs great but the problem I have is that the clutch belt is hitting the clutch housing while idling. Once it gets going it runs hard with no issue. I took off the clutch housing cleaned out but thats as far as I got.
The guy I got the quad off of told me he had replaced the belt recently. After 2 weeks of the kids riding It started rattling.
Any suggestions?
Thanks in advance, Mike
Old Jul 25, 2015 | 11:32 PM
95wolv's Avatar
The correct factory belt would never hit in the housing. double check to make sure it is the correct belt, this one could be a little bigger, letting it flop around when idling and not under tension. you may also want to check to make sure the engine mounts are solid, maybe the engine moves just a little, putting slack in the belt.
Old Jul 26, 2015 | 10:12 AM
Mikesohio's Avatar
Thanks Ill take a look at that. the belt does seem loose I can squeeze it in the center and easily both ends of the belt touches in the center. Is there any pulley adjustment tensioner on it?
Old Jul 26, 2015 | 10:51 AM
95wolv's Avatar
No adjustment, its like a snowmobile, you have to turn the secondary and open it a little to get enough slack to remove/install the belt, then the moveable sheaves take care of the gear ratios as the revs and load change on the engine.
Customer Service #1
May 15, 2020 08:46 AM
akguy31
Aug 31, 2019 04:34 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
snowolson
Aug 31, 2015 03:51 PM
