2003 polaris 250 2 cycle
Old Aug 17, 2015 | 02:21 AM
moneyrider's Avatar
Default 2003 polaris 250 2 cycle
So I just traded a boat for one of these it ran good and my friend was driving it and he heard a nosie. so he shut it off right then. I check the 2 cycle oil and it was empty.haven't put oil in it yet going to. but right after we shut it off. It wont fire back up. it cranks good with electronic start and sound good. motor still turned. So question is what wrong and do they have oil sensor that keep it from starting when it runs out.
Old Aug 17, 2015 | 07:39 AM
Scooter86's Avatar
Knows Old ATV Questions!
2 strokes don't like to be run without oil in the fuel. That noise was likely your piston dieing. Time to pull the head and look for scoring on the cylinder walls.
Old Aug 17, 2015 | 08:12 AM
moneyrider's Avatar
Default polaris
I did not hear what sound it made cause wasent driving when it did it. but it sound the same when I crank it when it was running and sound like it had good compression. sound pretty good while im pressing the start bottons cant hear no knock or bad sound during turning the key.u think it could got a little hot that why. u think if I put oil in it that it will start up it has 2 separate tank for it.1 for gas 1 for oil.I dont even drive it long pulled if off the trailer road it for 5 min to 10 mins and it dont die on me we shut it off then it won't fire like right after shut off
Old Aug 17, 2015 | 12:26 PM
moneyrider's Avatar
Got it fix the spark plug raddle out
Old Aug 17, 2015 | 02:50 PM
Scooter86's Avatar
Good, glad it was an easy fix!
Old Aug 17, 2015 | 05:28 PM
moneyrider's Avatar
Me too. the res was empty but when I change the oil some came out so I was completely dry
Old Aug 18, 2015 | 07:15 AM
You may have gotten very lucky! Oil in the reservoir tank doesn't have to be changed just topped off with a good 2 stroke injector oil. Only holds 2 quarts,but can usually last through 5-7 tanks full of gas.Sounds like someone just never checked it or the low oil sensor in the oil tank is either faulty or unplugged..
Jmuddin284
Jan 19, 2026 07:16 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
CRamshaw777
Jul 18, 2015 05:46 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
