Oil question Trans and diff aeon crossland 300 '07
Old Aug 24, 2015 | 10:06 AM
Haakon's Avatar
Default Oil question Trans and diff aeon crossland 300 '07
Hi
I just wonder what oil I should use in my tranny and diff? The owner manual is rubbish and says just "gear oil 85w/140.." hmm what kind? Gl4 /gl5, hypoid? I called the dealer and he stated "85/90 og Gear oil.." I asked gl4 or gl5, and he just replied "no gl4/5, just " 85/90 atv Gear oil"
The atv has shifting like reverse /neutral /forward/low gear and tranny belt. Can I use a oil with specs as fully synthetic, gl4/5 compatible 85w/90?
The tranny is just gears, and no clutches and does not require hypoid oil? What is hypoid for?
Any help is appreciated 😊
Old Aug 24, 2015 | 11:08 AM
Here's a couple articles on this that may help.LubeTrak Newsletter https://groups.google.com/forum/#!to...ch/jM9m87kbi00
Old Aug 24, 2015 | 11:35 AM
Haakon's Avatar
Thanks for the article old Polaris tech, but unfortunately I have no idea how the gears are cut, and I don't now if there are clutches inside the gearbox, but I'm pretty sure it ain't, cause then I would have filed atf oil who is a pretty thin oil. The transmission is like a moped, when the speed increase the variator pushes the belt so it's get wider in front, as in results the quad gets faster, but I'm not shure how it gets in gear, but I'm guessing on good old shifting forks.
Here's a spreadsheet of the tranny and it seems quite simple to me, but for all I know it can be more to it
https://drive.google.com/file/d/0B7k...p=docslist_api
And the diff
https://drive.google.com/file/d/0B7kOUGxxfpmDcTg4YURhUFh6MWM/view?usp=docslist_api
Would you guys try the fully synthetic 85w/90 with gl4/5 specs? In my understanding I can't see what can go wrong.
Old Aug 24, 2015 | 01:07 PM
Then see if this helps. If not there's a forum for this machine.Oil for AEON Cube Cube 300 (2007 and after). Which oil is the best? Professional lubrication advice - Kroon-Oil
Aeon Crossland 300 discussion group
Old Aug 24, 2015 | 01:54 PM
Haakon's Avatar
Thank alot! the fluid of recommendation was gl5 and hypoid based, 80/90 viscosity. Then it's easy to buy the correct oil😄
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
John Reed
Sep 9, 2015 03:46 AM
