Polaris magnum 325 help
You can either remove and flush the tank or if you have a compressor you can insert a siphon hose, use an old shop towel and air nozzle and pressurize the tank and force the gas out. I did that quite often on the old water craft.Sitting that long,carb needs to be cleaned and rebuilt. Plenty of kits on ebay for your machine.Polaris Magnum or Trail Boss 325 2000 2001 2002 Carb Carburetor Rebuild Kit | eBay Plus look at the pdf fuel section from the manual. Can help on carb cleaning and float adjustment.https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA
