2008 polaris 500 sportsman
Old Jan 12, 2016 | 12:01 PM
oscar123's Avatar
Default 2008 polaris 500 sportsman
My quad is backfiring while riding. Seems like it happens every 10 mins or so and lasts about a minute or two. Also i went through a small puddle that caused a splash and the bike quit. It started after a minute or so. Any ideas where or what to look for? I'm thinking that the 2 issues are related just looking for a where to start looking solution to the problem.
Old Jan 12, 2016 | 12:04 PM
Efi or carb model?
Old Jan 12, 2016 | 12:06 PM
oscar123's Avatar
Efi or carb model?
Efi... thinking maybe a coil wire???
Old Jan 12, 2016 | 12:24 PM
Thinking more inline with the tbap connector and harness as the back firing is usually a sign that's where the problem is. Common problem on efi machines and the thin sensor wiring. Not so much the sensors themselves.You can get a better repair kit here for the 500 Only The Best than what Polaris sells.Plus look over this "sticky" post on efi problems on the 700/800 machines which includes the 500 also.https://atvconnection.com/forums/pol...ap-wiring.html Plus codes may or may not show up if with wiring or connector problems. You can try to jiggle the wiring leading down from the sensor into the harness and see if you notice a change in the engine. Can be a bare wire,soft internally melted wire,or a wire may have pulled out of the cheap connectors.
Old Jan 12, 2016 | 12:32 PM
oscar123's Avatar
Ok thanks ... will start there
Old Jan 12, 2016 | 12:45 PM
Didn't notice about the puddle either.. I'd pull the electrical connectors and blow them out first and use some electrical grease. Hopefully that may be the problem. If not,I'd check into the tbap harness. Same thing on the plug cap. Pull it,blow out any water around the plug and put a dab of electrical grease around the cap lip.
Old Jan 12, 2016 | 12:49 PM
oscar123's Avatar
Didn't notice about the puddle either.. I'd pull the electrical connectors and blow them out first and use some electrical grease. Hopefully that may be the problem. If not,I'd check into the tbap harness. Same thing on the plug cap. Pull itblow out any water around the plug and put a dab of electrical grease around the cap lip.
Ya it happened when pressure washing it one day too when i sprayed behind the right front wheel (throttle side) it was running and quit. Started back up a minute later. Thanks
fhorta
Dec 17, 2015 07:53 AM
crkola
Dec 11, 2015 01:47 PM
Jim MgGinn
Dec 4, 2015 01:01 AM
Thatguy23
1) Engine problems..
Nov 3, 2015 03:10 AM
