Cleaning
Old Jan 24, 2016 | 09:54 AM
Matthew30's Avatar
Default Cleaning
Can somebody tell me how to wash my sportsman 800? I've heard no and yes on pressure washers.
Old Jan 24, 2016 | 10:34 AM
Water hose,soapy hand mitt is best. You can power spray around wheels and suspension,but be careful around wiring and connectors. If you do pressure wash I'd take the time to dry out wiring and use electrical grease in connectors. I can't remember how many machines showed up at the shop for non starting issues after pressure washing. Just use common sense on this.
Old Jan 24, 2016 | 12:53 PM
user493's Avatar
Moto Psycho
If you do use a pressure washer be very careful. They have enough power to blow decals off. Now imagine that amount of pressure hitting your CV joints. You could wash the grease away and fill them with water. Same thing with other areas. I heard someone say to use a pressure washer with the pressure turned down. Why not just use a hose? I use a hose, a bucket of warm water with dish soap in it, and a big sponge. I'm thinking of using rags instead of the sponge next time because it's old and getting torn up.
Old Jan 24, 2016 | 02:56 PM
Alex G.'s Avatar
pressure washers are great, you just need to use a bit of common sense. If you hold the tip too close to a cv joint boot you'll destroy it... if you hold it too close to a electrical connector you'll destroy it... if you hold it too close to your radiator, there is a good chance you'll bend the fins. Water gets in connectors no matter if you use a hose, a pressure washer or a creek/stream/puddle.
Old Jan 26, 2016 | 09:35 AM
Zrock's Avatar
Super Quad Patrol
i agree. i have used pressure washer on all my machines with 0 issues including washing the rad. usually i just let em sit and dry after
Old Jan 27, 2016 | 11:46 AM
SOLOLUCKY's Avatar
I would vote NO on pressure washers across the board...its just overkill..you can , in most cases, achieve a clean machine with a rag, brush and soapy water and a hose with a sprayer nozzle. the risk of what a pressure washer can do that is bad aint worth it to me
Old Jan 27, 2016 | 11:58 AM
Zrock's Avatar
Super Quad Patrol
You must not have tried to clean a machine after a day of playing in the mud especially clay. Last time I try ed a hose for that it took over 4 hours and it still had clay packed in places. Use common sence when using presure washer and u will have no issues
Old Jan 27, 2016 | 07:14 PM
Alex G.'s Avatar
Dans_700sports
Dec 4, 2016 07:21 AM
keithfed1
Jan 30, 2016 06:28 PM
Joe04785
Jan 25, 2016 12:12 AM
Dans_700sports
Jan 24, 2016 08:05 AM
jppaving
10
Jan 22, 2016 10:10 AM
