400ex help
Old Feb 15, 2016 | 07:24 PM
etstern's Avatar
Default 400ex help
I bought an 04 400ex but the neutral light won't go off even when the keys off only if its in gear
Old Apr 11, 2016 | 04:15 PM
WalterTalt's Avatar
Daily Rider
ah i had this problem too check all the wires up front under the plastics make sure they are all connected correctly also check your neutral safety switch on the left side of your engine its just a wire that runs to the bottom of your case on the exterior you will see it
my problem was the neutral light didnt go off and i didnt need a key to start it then i did the wiring correctly re connected some things and i was good!
Old Apr 11, 2016 | 04:32 PM
Swerve400EX's Avatar
Cross Country Rider
Your neutral light is running directly to hot. Trace it and run it to ground.
Rdorr91
Mar 1, 2016 08:24 AM
HerpDerp1919
Feb 16, 2016 12:39 PM
etstern
Feb 14, 2016 08:48 PM
needlenose
Jan 29, 2016 08:14 PM
