Polaris loose front suspension
Old Feb 27, 2016 | 11:26 AM
Chris.400's Avatar
Default Polaris loose front suspension
I need help. I just replaced all bushings in the lower control arm, front left. I checked the bearing and it was tight as can be and not loose at all. but i put it all back together and everything is still loose.
What I mean is if I have the wheel on and pick up, there is about half an inch of wiggle room going up and down. What does this mean?
Old Feb 27, 2016 | 11:44 AM
That's where the manual link I posted can help. Could be not enough torque on hub nut or ball joint loose?
Old Feb 28, 2016 | 05:12 PM
Chris.400's Avatar
They are all torqued to spec. i don't know at this point. I might replace the bearing and hope for the best. Is there a specific brand of bearings you like the most? i run decent sized mud tires so they will be supporting a bit of weight.
Old Feb 28, 2016 | 09:50 PM
Here's a good place that you can crossover Polaris part numbers on bearings and seals and are pretty cheap..http://www.hyperparts.com/wc.dll?ctw...~00043~Polaris Even ebay has some decent prices.05 16 Polaris Sportsman 300 400 450 570 Front Wheel Carrier Bearing RPL 3514634 | eBay Or you can take the universal number on the bearing and check your local auto parts. Plus here's a list that people have compiled for 700 parts,but many will interchange with other models.
Old Feb 29, 2016 | 04:37 PM
Chris.400's Avatar
Yes i understand they have cheap prices. But I want long lasting under lots of pressure and water lol. Price isnt really a problem for me.
Old Feb 29, 2016 | 05:16 PM
Three of the best.. You can match up your universal bearing number.
http://www.timken.com/en-us/products...s/default.aspx
Ball Bearings - SKF
Ball Bearings | Products | NSK Global
Plus some like All *****. These you can get on ebay.
Forgot another good one that's used a lot in atvs. Koyo bearings.http://www.koyo.eu/en/products.html
Old Mar 13, 2016 | 11:09 AM
Chris.400's Avatar
Put a new bearing in it, It is a lot tighter. Still a little play, think its a tie rod.
Old Mar 13, 2016 | 11:43 AM
Look towards the bottom of this list. May help on replacement tie rods rather than paying oem prices.Make a list of common numbers we need | High Lifter Forums
mustangmatt70
Mar 29, 2016 08:04 PM
hunter56
Mar 11, 2016 02:43 PM
u09692
Feb 28, 2016 12:01 PM
Snky
Feb 8, 2016 07:13 AM
Ride 4 Ever
Technical and How-To Articles
Jan 29, 2016 01:27 PM
