idle is all the place after valves done
Old Apr 15, 2016 | 06:52 PM
rui74's Avatar
Originally Posted by rui74
Ok, plastics are all off, both cable have good slack no binding and idle is down a bit to abut 1650. That is still high and a bit erratic can't figure out why it would be this high it was fine prior to valve adjustment.
Played around a bit with choke cable into carb and throttle cable and idle screw and doing that seems to have fixed idling perfectly at 1190 to 1200 spot on. Thanks OPT.
Old Apr 16, 2016 | 02:57 AM
Figured you'd find the problem once you retraced your steps.. Good luck on it.
Old Apr 16, 2016 | 03:29 PM
Fasteratv's Avatar
Idle it down the 1100 to 1200 or so after it warms up....then adjust the air/fuel adjustment for max idle RPM, then adjust the idle again. Are you sure all the boots...carb and airbox are good and tight...no leaks?
Old Apr 17, 2016 | 09:00 AM
Fuel screw is blocked off on these models with an aluminum plug. Usually preset from the factory pretty close.
Rluckie
Mar 7, 2016 10:53 AM
Kerabo
1) Engine problems..
Feb 20, 2016 09:51 AM
JunkQuad
Feb 19, 2016 10:59 PM
Ckieffer29
12
Feb 16, 2016 05:03 AM
keeperstweed
Jan 21, 2016 11:14 AM
