Battery?
Old Aug 29, 2016 | 02:32 PM
buffadonk's Avatar
Default Battery?
So I was riding yesterday and I started smelling something real bad. I took the seat off and the top of the battery was forced open with air coming out of it. Anybody know why it would do that? The battery was new.
Old Aug 29, 2016 | 02:48 PM
panicmanic's Avatar
1st step would be take the batt back to where you bought it ASAP!
Old Aug 29, 2016 | 02:58 PM
Either the battery is just faulty or an overcharging regulator can cause something like this to happen also when a battery overheats.
Old Aug 29, 2016 | 03:30 PM
buffadonk's Avatar
I just checked the regulator and it showed about 500 on the pins that gave readings with 491 the lowest. I was watching a video an one of the pins he said was faulty on his didn't give a reading on mine at all.
Old Aug 29, 2016 | 03:35 PM
Pins? What was dc voltage at the battery while engine was at an idle? I've found some as high as 17-18 volts when they should have been charging 14-14.5 volts max..
Old Aug 29, 2016 | 04:03 PM
buffadonk's Avatar
idle it's about 9.5 I gave it a little gas it went over 21
Old Aug 29, 2016 | 04:11 PM
That's the problem on the battery bubbling and over heating.. Usually the regulator when this happens,but if you have the manual not a bad idea on checking the stator specs out also just in case.
Old Aug 29, 2016 | 04:26 PM
buffadonk's Avatar
OK I just ordered a new regulator I don't have the manual for it but if it but I'm sure I can find one. Thanks for the help.
Old Aug 29, 2016 | 05:44 PM
Kymco 450i's Avatar
Make sure you clean that area real good as any acid from the battery will linger and cause corrosion. After a thorough washing spray it down good with something like WD-40 to stop any corrosion from happening. Man that sucks with a new battery.......
Old Aug 29, 2016 | 06:23 PM
user493's Avatar
Moto Psycho
Baking soda and water will neutralize the acid when you clean up the area.
