Clutch problems
Old Aug 31, 2016 | 04:30 PM
89softail's Avatar
Default Clutch problems
My 03 sportsman 700 has problems. I replaced my driveable months ago, then a friend rode it and I think he forgot to use low gear. I took the side cover off after hearing a noise. The belt is loose and the outer clutch plate moves loosely. It's like the the spring is worn and it's not pushing it in to tighten the belt. Polaris Tech are you around ?
Old Aug 31, 2016 | 04:55 PM
Only way to see what damage has been done is to pull the clutch,remove the snap ring,helix,spring and check the rollers out. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse
Old Aug 31, 2016 | 06:25 PM
89softail's Avatar
What should I look for once apart ?
Old Sep 1, 2016 | 07:38 PM
89softail's Avatar
Default What to look for
Once a take it apart, what am I looking for ? Making a noise when moving in gear.
Old Sep 2, 2016 | 07:47 AM
Main things to look for are the three rollers for wear and the helix itself where it ramps on the these rollers.This could be where the noise is coming from.
Old Sep 2, 2016 | 11:09 AM
DirtDevil101's Avatar
"moves loosely"...like in & out? Sounds like spring broke or popped out of its guide...but like OPT said, ya need to pull it apart to find out...take pics, we can guide you from there is not already obvious...
superunknown23
Feb 23, 2016 12:39 PM
JaemsChimney
Feb 22, 2016 11:44 AM
SOLOLUCKY
Jan 30, 2016 06:31 PM
SOLOLUCKY
Jan 25, 2016 08:02 AM
Fred250R
Feb 22, 2000 12:13 AM
