1997 Polaris xplorer burning coolant out exhaust.
Old 12-30-2016, 01:09 PM
Joshuajay13's Avatar
Default Old Polaris Tech
What would you recommend for a rebuild kit? Bearings etc?
Old 12-30-2016, 02:47 PM
Several different kits from just gasket/seal kits to full gasket,seal and engine case bearings on ebay.http://www.ebay.com/itm/WINDEROSA-COMPLETE-ENGINE-GASKET-SET-TOP-BOTTOM-END-POLARIS-400-2-STROKE-94-02/232104163506?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D38530%26meid%3Dacd33afb680a49feb2e0e124470e42a7%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D142219249399 Polaris ATV 400 400L Complete Engine Gasket, Bearing & Oil Seal Rebuild Kit Main thing to check on the bottom end is the three crack bearings and the lower end rod bearing. NO up and down play allowed on the rod. Side to side play is ok.Machine shops or dealer can install new rod kits if needed and true the crank shaft. Also you need to check the large bearing on the counter balancer. Depending on what shape the counter balancer is in,there are several places that can rebuild yours if needed as a new one is over $550. This doesn't include a new piston kit and cylinder bore and can get a little expensive to rebuild a 400,but way too many people that post on these forums trying to just patch one up.A lot of times that doesn't work on this engine and problem after problem crops up..
