300ex issue please help!!
Old Apr 24, 2017 | 05:40 PM
Cody300ex's Avatar
Default 300ex issue please help!!
I have a 97 300ex and for some reason gas keeps getting in my oil. And its revving by its self sometimes. What is the problem?
Old Apr 24, 2017 | 10:07 PM
Collar Bones's Avatar
I would say the float valve/needle valve is leaking through or it's a problem with the float.
A thorough teardown, inspection, and cleaning of the carb is in order. Clogged air bleeds can also cause internal leakage.
Assuming this machine doesn't have a vacuum operated petcock, those can leak fuel through the vacuum line.
I'm suspecting an air leak also, since the engine seems to use the extra fuel to rev up. It should be flooding/running rich if it's getting extra gas via the oil. Instead, it's revving. Check the carb/intake boots while the carb is off.
Old Apr 25, 2017 | 08:11 AM
Cody300ex's Avatar
thats what I was worried about Haha
