Recovery rope question
Old Jul 29, 2018 | 08:38 AM
Jbo225's Avatar
Default Recovery rope question
I'm in the market for a recovery rope I'm going to go with a voodoo but my question is what length should I go with? whats the pros and cons of a 16ft or 20ft (the choices)
Old Jul 29, 2018 | 11:02 AM
Kymco 450i's Avatar
In my opinion you can always make it shorter but you cant make it longer!!
Old Jul 29, 2018 | 11:17 AM
Jbo225's Avatar
You do have a point there
Old Jul 29, 2018 | 11:36 AM
greg74's Avatar
Or you can always get 2. Even if you have a winch, sometimes you're too far away from a tree to winch yourself out.
Old Jul 29, 2018 | 12:46 PM
Zrock's Avatar
Super Quad Patrol
With a 28% stretch you may run out of trail before you snug it tight.. Personally i have only ever run a 10ft tow rope and never needed longer for poping someone out of the mud or using it for around a tree for winching. Anything farther than that for us is usually a winch recovery anyway.. Only time mine comes out is when were are playing in the mud..
Old Jul 29, 2018 | 03:34 PM
greg74's Avatar
I think mine is a 25 ft. Its actually an automotive recovery strap so its a lot stronger than I'll ever need it to be. I've used a few times recently to pull others out and once to wrap around a tree to extend reach to winch a rzr out of the mud.
Old Aug 1, 2018 | 12:02 AM
Specta's Avatar
I've had over 100 ft of recovery rope out once when I got stuck in the snow.
I have 2 - 50' synthetic ropes looped with hooks on both ends.
The two above are 25 footers cut from a 50' synthetic rope plus 3 or 4 tow straps from 12 to 15'.
Overkill I know but you just never know what you're going to need.
Old Aug 1, 2018 | 10:46 AM
RedRocket204's Avatar
Specta, same here. From seeing where you ride and where I ride, higher altitude/high country, at times there can be limited anchor points and it really helps to have that extra reach of 100'. So yeah, I travel with 50' syn rope on my winch and a secondary 50' syn rope with the other recovery items, 20' tow strap, shackles, etc. And I have also had to break out that extra 50' syn rope as I was stuck in snow too.
Old Aug 1, 2018 | 10:50 AM
Kymco 450i's Avatar
I have 25 on the winch plus two cables, 25 and a 50 plus 25 of syn rope and this was still to short at a ride last fall. Buriwd in mud and nearest tree was 150 ft away. So in my opinion you can never carry to much!
Old Aug 1, 2018 | 12:25 PM
Specta's Avatar
Its always better to have more than you need.
Counting what's on my winch spool I probably have close to 230 ft. A nice tree saver strap and two ****** blocks.
The best reason for over kill is its insurance that you'll probably never need it. LOL
