2009 Polaris sportsman 400.
Old Jun 7, 2020 | 09:46 PM
Ron Hunter's Avatar
Default 2009 Polaris sportsman 400.
2009 sportsman 400. Has me stumped. You can get it to fire but runs pretty rough, smokes a little and won’t idle. Checked valves, replaced head-gasket, cleaned carb, new plug, checked the timing 3 times. For life of me I can’t figure out the issue. Unfortunately I can’t find much info online with people with the same issues?? And suggestions ?
Old Jun 8, 2020 | 08:50 PM
Kymco 450i's Avatar
What is the compression? What color is the spark and will it jump a 3/16 gap? Did you use a good carb rebuild kit or just a clean and reuse old parts and gaskets?
Old Jun 9, 2020 | 05:45 AM
Ron Hunter's Avatar
Compression was 80+ pounds. Cleaned the carb, it did have a main jet was a little clogged up but everything else seemed to be fine so we cleaned it up and put it back on. I may get a new rebuild kit for it yet. As far as the spark color and gap goes I’ll have to look into that and get back with you.
Old Jun 9, 2020 | 07:37 AM
Kymco 450i's Avatar
Compression is pretty low, needs to be over 100. Add a squirt of oil in the cyl and check again, if it comes up you have a worn cyl, if it stays low, you have bad valves or out of time.
Old Jun 9, 2020 | 07:42 AM
Ron Hunter's Avatar
Service manual states 50-90 on compression. Also the four wheeler only has 300 miles on it.
Old Jun 9, 2020 | 08:33 AM
Kymco 450i's Avatar
Ok....that is a low one, most are 110 plus.....is this a 2 stroke? If you rebuild the carb, get a good kit for the factory carb and rebuild with new gaskets. It only takes a teeny tiney spec of dirt to cause problems
tompeter
Feb 15, 2020 01:41 AM
polaris man with issues
Dec 17, 2010 11:16 PM
RticKwad
Jul 14, 2008 08:36 PM
jimmypsp700
Jul 9, 2008 09:46 PM
