To change a PVT belt?
Is it possible to change a Polaris Ranger PVT belt in the field? Difficulty level? Tools required? If not in the field, can it be done by a mechanically skilled person at home? This question is coming from a potential Ranger owner that is a long way from the dealer, and ventures a LONG way from the highway.
This covers the belt replacement on a 6x6, but it should be the same for any Ranger. Fairly simple job and could easily be accomplished in the field.
http://utilityoffroad.com/tech/ranger/belt/index.html
Jamie
Jamie
Thanks Spool! This forum is worth it's weight in Gold! Going UTV shopping tomorrow, and probably a purchase. I do not particuarily like belts, but now I know it is not a big hassle to deal with one broken on the trail. I would presume other brands are similiar, but will query the dealer prior to any purchase. The article also answers my question in regard to the necessary RPM at low speeds.
I don't think the Yamaha Rhino or Arctic Cat Prowler would be as easy to change. They both use a CVT system were the belt is held at tension at all times so it might not be possible to work it over the pulley. Of course I've never heard of a belt failure on a Yamaha so it wouldn't be as worrisome to begin with. You might want to check out the forums at utilityoffroad.com
Jamie
Jamie
