Performance
Old Jan 28, 2007 | 05:35 PM
funindamud's Avatar
Default Performance
Does anyone know where any performance adders (carbs, exaust.........) for a carter brothers talon go kart??? please help!!!!!!!
Old Jan 28, 2007 | 06:36 PM
learnem's Avatar
Default Performance
I would assume that you could find out the size of your carb, and maybe go up a few mm in size to increase the power output. you will have to jet of course
Old Jan 29, 2007 | 09:14 AM
billl2099's Avatar
Default Performance
for more information on your talon and performance parts head on over to buggynews.com, this site all about mini buggies,
Old Jan 29, 2007 | 11:22 PM
Spool's Avatar
Default Performance
Yeah you definitely want to check out buggynews.com, it's an excellent resource for these buggies. I have an '05 Twister Hammerhead 150 (virtually identical to the Talon) and love it. For about $50 worth of parts you can really wake these machines up. You'll be surprised at how well 150cc perform.
Check these posts for starters:
http://www.buggynews.com/topic4314.html
http://www.buggynews.com/topic3177.html
enjoy the Talon.
Jamie
Old Jan 31, 2007 | 08:45 PM
funindamud's Avatar
Default Performance
thanks for all of the info
i'm thinking about buying a high performance camshaft for more acceleration, and some high performance carburetor jets from awesomebuggy.com
what do you reccomend for a nother mod? i allready have a K&N filter with some large radiator hose attached to it running to the carb. and all of the baffles are cut out of the exaust.
Old Feb 3, 2007 | 02:50 PM
Spool's Avatar
Default Performance
What year is your Talon? If it's a 2004 the cam will be a good gain however the 2005 and up Talon DLX comes with a pretty aggresive cam stock so you won't see much gain by installing a new one. The best mod by far is to replace the rollers in the CVT with lighter ones (9 or 10 grams) and putting in a stiffer clutch spring. You will see huge gains in hill climbing ability with those mods. Hills that I could not climb at all when stock I can now climb at 1/2 throttle after the changing the rollers and spring and gutting the exhaust, adding a UNI filter intake (eliminating the restrictive stock airbox/snorkel setup) and rejetting the carb.
Jamie
Old Feb 3, 2007 | 03:04 PM
Spool's Avatar
Default Performance
I see you're located in Kentucky. Buggynews.com will be holding it's second annual Buggy Bash at Paddy's Bluff ATV park in Dycusburg, KYon June 22, 23, and 24, 2007. You'll definitely want to check that out.
here's a link for the bash:
http://www.buggynews.com/topic8128.html
Jamie
Old Feb 3, 2007 | 06:44 PM
funindamud's Avatar
Default Performance
i think my talon is a 2005 but i'm not shure, i've allredy gutted the exaust, and added a intake kit and a K&N, i'll look into getting a clutch spring..... and i'm thinking about goint ot pattys bluff, but it's about a 1 1/2 hour drive from where i live....
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
