Help With Forum Software! A Place to get Help with the Forum.
04 Suzuki Eiger new carb help
Old Mar 29, 2023 | 06:01 PM
Adamjp2004's Avatar
Default 04 Suzuki Eiger new carb help
I have an 04 Suzuki Eiger that had many of the common carb problems. Most noted was back firing through carb. I have tried cleaning and rejetting with no success. Set valves which were already nearly spot on. I just installed a knock off Chinese carb which matches the original exactly. Atv runs great now with no spitting and sputtering. Only issue is atv starts with no choke even when cold. Also there is the smallest flat spot between idle and half throttle. My experience tells me the pilot jet is too rich. Spark plug doesn't look black. Since it is 100 times better than before is there anything to worry about. I searched the threads and couldn't find much info. Any help would be appreciated.
Also I see I clearly posted in wrong section and can not find how to move it.
Last edited by Adamjp2004; Mar 29, 2023 at 06:06 PM. Reason: Posted in wrong section
Angel Gracia Cordero
Mar 19, 2020 07:50 AM
drb94
Apr 25, 2019 04:09 PM
D.Anderson1
Aug 15, 2018 11:34 AM
leerobinson
Jun 14, 2013 02:16 PM
Richardg
Dec 16, 2009 09:36 AM
