400ex starting problem
Old Jun 5, 2003 | 12:53 PM
ElectricShift's Avatar
Default 400ex starting problem
The way i understood it is he hit the started button, and all it did was click one time.
I had the same exact problem on my yamaha moto-4 and on one of my jetskis...I had to have the starters rebuilt on both of them and it only cost me 50 dollars at a local atc repair shop.
Old Jun 5, 2003 | 06:13 PM
yellowexracer's Avatar
Mine did that too, whenever I went to push the starter it made a single click. I checked and the ground on the battery was loose.
Old Jun 5, 2003 | 06:27 PM
RacinJason's Avatar
Simply "jump" the starter relay by touching a insulated pair of pliers to both posts(with the switch in the on position)
If this starts your bike(I think this is your problem) you need to replace the starter relay
If the same thing happens check to be sure all the cables are tight
Still no luck...replace starter brushes
Old Jun 5, 2003 | 07:44 PM
swftballz400ex's Avatar
I had the smae problom a few weeks ago one click and that was it i would fool with the relay and it would start. I found out the problem was just a loose connection tightened it up and has worked fine since
DTroyer01
Jul 3, 2015 07:34 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
