400ex starting problem
Old Jun 4, 2003 | 06:04 PM
Beefy400's Avatar
Default 400ex starting problem
yesterday i had a problem starting the quad. i originally thought it was a dead battery however after testing it i knew it wasnt it. it wouldnt even turn over all there was was one click every time i tried to start it so i took apart the battery and i found out if i fooled around with the circular box that has the ground and power wire for the starter it would fire right up. i looked around and there was little to no corrosion on the terminals so i really dont know what it is the only other thing i could imagine was since i was in really wet conditions last weekend that could have something to do with it... did anyone else have this problem? any suggestions? thanks
Old Jun 4, 2003 | 06:13 PM
QUADBOY327's Avatar
hey i had thast same pro last week and i couldnt figure out anything either i took mine to the shop and they said wat i thoguht it was the SPARK PLUG [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jun 4, 2003 | 06:15 PM
peck15's Avatar
hey anyone outthere
Old Jun 4, 2003 | 06:16 PM
peck15's Avatar
im new to this
help me out haha
Old Jun 4, 2003 | 09:31 PM
cals400ex's Avatar
hey peck, i am not sure what your asking?
Old Jun 4, 2003 | 09:46 PM
dzzy's Avatar
Yes, if your battery is good, check all the big cable terminals, on the battery, on the chassis, and on the box you referred to, lets call it a starter relay, even the one on the starter itself. If they are all clean and tight, it could be the starter relay itself. If it does it again, tap on it with a soft hammer or screwdriver, if it turns over, then replace that relay. It could have gotten moisture inside of it and corroded it.
Old Jun 4, 2003 | 10:47 PM
peck15's Avatar
my 400ex wouldnt start one day back in winter...
all i done was took the plug out turned on the choke dipped the plug in some gas put the plug back in and it started right up i juss had ta play with choke for a few minutes and it ran juss fine!!!
Old Jun 4, 2003 | 11:33 PM
ElectricShift's Avatar
The brushes in your starter are bad.
Old Jun 5, 2003 | 09:20 AM
dzzy's Avatar
The way I understood the problem was that the starter wouldn't turn, not that the machine wouldn't run. ElectricShift could be on the right track too. The fact that it began to work when you "fooled around" with the starter relay makes me think that's a possibility, even though usually if they click they're good. A poor connection on any one of the big cables is high on the list too.
Old Jun 5, 2003 | 11:24 AM
JBMAN's Avatar
Hey Thread uf you have a after market rev box trash it they will cause your bike not to start also. But it sounds like poss. startor to me.
