valve experts
i have a 400ex and its in need of a valve adjustment. i remember hearing a few things about valves. i just can't remember if you will gain a little topend or lowend when the valves are a little loose. i think you should gain in the opposite area when you have then a little tight. the bike is stock besides air box mods and a pipe. thanks
If they say .004" to .006", I set them at .005". I don't buy there is any significant gain by varying the clearance within the specs. If anything, I guess performance wise it would be better to go tight as the valves are open a little longer, but too tight and presto burno valve. Also your valve is then that much closer to the piston, increasing the possibility of interference.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
