81-250R RUNNING RICH?
Old Jun 10, 2003 | 08:27 AM
billsz28's Avatar
Default 81-250R RUNNING RICH?
EVERY TIME I START MY BIKE UP IT WILL RUN FOR ABOUT 7-10 SECONDS THEN DIE. I PULL THE SPARK PLUG AND SEE THAT IT IS ALWAYS FOULED WITH TOO MUCH FUEL. I HAVE CHANGED OVER THE CARBS, CHECKED THE TIMING MARK,AND EVEN MADE SURE THE THROTTLE CABLE WAS WORKING FINE. BUT CANNOT CORRECT PROBLEM. ANY IDEAS?-MAYBE IRRATIC IGNITION?ANY HELPFUL HINTS WOULD BE APPECIATED.THANKS.
Old Jun 10, 2003 | 01:39 PM
Billsner's Avatar
carbs are not that bad, stay calm. start with your oil to gas ratio (~32/1) then check the pilot jet.
Old Jun 10, 2003 | 01:43 PM
matthewnkaty's Avatar
This might be a stupid suggestion but that happend to my friend. He found his tube thru his gas cap was clogged and it would vapor lock.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
robj
Jun 15, 2015 08:45 PM
Chawness
Apr 21, 2000 08:14 AM
