adajusting valves and spark plug gap?'s fer a 300ex.
Old Jun 22, 2003 | 02:16 PM
redranger1's Avatar
Default adajusting valves and spark plug gap?'s fer a 300ex.
can anybody tell me what all is involved in adjusting the valves? im getting some rattling from my upper and i think thats the problem. also, what spark plug gap should i have? thanks, nathan.
Old Jun 23, 2003 | 09:37 AM
dzzy's Avatar
Remove the fuel tank, spark plug, tappet covers, and inspection plugs on the left engine cover. Turn the engine over via the flywheel nut, and look for the F and the T marks in the smaller inspection window. You must find T on the compression stroke, there seems to be a lot of confusion about this. Here is a method for finding TDC compression on ANY four stroke. First, determine the correct engine rotation. You can do this by pecking the starter button and watching the flywheel nut, or use the F (fire) and T (TDC) marks. F always precedes T in engine rotation. Turn the engine over slowly the correct way, and watch the intake valve rocker open the intake valve, and then close it completely. The very next T is ALWAYS the compression stroke. Both valves should be closed completely. Loosen the tappet adjuster locknut and stick the correct size feel gauge between it and the valve stem. When you're done the feeler should fit snugly. Reinstall your parts and you're done.
Old Jun 23, 2003 | 09:41 PM
redranger1's Avatar
thanks dzzy, i sure appreciate it. i kinda figured that was how it was done caus we do it on the pullin truck and the blower engines in the boats i work on like that. i just wasnt certain since it was so much smaller then a 530ci bb. thanks, nathan.
Dirtbikemike1
Jul 21, 2015 04:13 AM
ghost civic
Jul 19, 2015 10:13 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
