Problem with a 300EX Help ME OUT (Been 1 Month)
#21
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2422829593
here is a wiring harness if you are still looking for one. I found it on ebay.
I hope this helps
I hope this helps
#22
Thanks Paul, Anyways the guy who sell this harness don't want to send to Canada. I found another one willing to send everything to Canada. The thing is that I just don't want to order thing I don't need. The problem is surely the coil or the harness.
When I think about it ? Could it be the rotor/stator?
#23
Can somebody tell me if my coil is still good with the informantion I'Ve given?
RaptorJay, The problem with your test is that I need a starter and I will probably have a new coil at the same time I get a starter [img]i/expressions/face-icon-small-blush.gif[/img]
#24
Will my problem be solved since I bought off ebay :
- A starter
- A solenoid
- CDI BOX
- REVERSE SOMETHING BOX
- Coil
- Whole Wire Harness
I hope and imagine so [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img] [img]i/expressions/face-icon-small-wink.gif[/img]
- A starter
- A solenoid
- CDI BOX
- Coil
#27
I really dont think its the stater, only because when I was having this problem I took it to a shop to figure out the problem I was having and they replaced my stater and it still didnt solve the problem. I also replaced my coil and that wasnt the problem either. Like I said before it was a loose wire connection in the white part of the wireing harness that connected to the CDI box. I spent alot of time, and money at two different shops trying to fix this problem. about 500.00 after it was all said and done, to find out it was only the wiring harness.
#28
PaulV, the problem is still not solved. Still haven't ordered anything yet. Is there anyway I can know If my problem is the same as yours? Can I detect it with a multimeter?
#29
dude, if ur still having problems after everything that everybody's told u, take the thing in to where u bought it at! if u haven't changed ne thing, then it might be under warranty. us take it in and let them fix it for u.
