250x
Old May 16, 2000 | 07:21 PM
quadamaniac's Avatar
Can you all tell me the specs on a 250x? What was the best year for them? 2 or 4 stroke? Recomendations? Top Speed? Suspension? Any other things I should know about?
Thanx~!
Old May 16, 2000 | 08:39 PM
rking85's Avatar
hey. i am looking for info on 250x's too. I know the suspensoion is the same as a 300ex and the same about everything else.
Old May 16, 2000 | 09:50 PM
cjpd's Avatar
I have a 1992 250X. It is 4 stroke,it is the same thing as a 300EX except the 250X is not electric start and the cylinder is board one size down from the 300EX.They board the 300EX out a litte more to compinsatate for the add'ed wait from the electric start.I think your best bet to get all the spec's it to call a honda shop near you.I recomend a 1992 because that is the last year they made the 250X you just have to be cairfull on what you buy.
Old May 16, 2000 | 11:20 PM
daniel6543's Avatar
i've got an 87 honda 250x.Its getting a little old,but they are good machines.mine will do about 57 stock,and they arent bad jumping quads either
Old May 17, 2000 | 01:57 AM
ATVgirl's Avatar
You can check this site to find some specs on the 250X http://www.webspan.net/~rpfirley/index.htm Just click on ATV's and then select your machine.
Monica
1997 300EX
Old May 17, 2000 | 02:16 AM
puddding's Avatar
search the site!....lots of info in previous discussions
Old May 17, 2000 | 12:08 PM
one1drboy's Avatar
Hey, quadmaniac, here is the scope.
1. 250x and 300ex are the same bike, suspension and frame wise. They both have the same amount of suspension travel front and rear. Look at some place like Rage Performance and every thing listed for a 300 is also listed (same model #'s) for the 250x.
2. The plastic is interchangable.
3. Both are four Strokes and gearing in the transmission is the same. The 250x is a 246cc and the 300ex is a 282cc.
4. The 300ex out weighs the 250x by about 25 lbs. The difference being the starter and battery.
5. The 250x is kick start. My 250x runs really well and will start on the first or second attempt when it's cold. First time every time when it's warm.
6. Go look at them, sit on them, then imagine putting the bikes in reverse. The 300ex requires the rider to seek help from at least teo bystanders and one other helpful soul to get the dern thing into reverse. The lever is buried under the seat, above the engine. The same issue is not as bad on a 250x, however the rider must reach down on the left side of the bike with the right hand while holding in the clutch. The rider on a 250x can learn to shift into reverse with a properly placed heal stroke on the left foot. I do believe someone makes an aftermarket shift lever for the 300ex, that helps with this issue.
7. Biggest differnce I found when looking to buy either one was price. 300ex's run about $1000-$1500 higher than a comparable 250x. Since I don't have an extra $1000 laying around I bought a 250x in great shape.
Good luck and look the machine over really well before you hand over any cash.
Old May 17, 2000 | 03:36 PM
Y2K300EX's Avatar
Actually the 300ex and the 250x have the same bore. The 300 has a longer stroke.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
