HELP EXCESSIVE CAMBER/CASTER!!!
Old Jul 14, 2003 | 07:17 PM
CrAcKhEaD's Avatar
Default HELP EXCESSIVE CAMBER/CASTER!!!
i just put some 400ex spindles on my R and now i have excessive camber or caster im not sure which is which but the top of the tire is facing outwards
\___/
[ ] [ ]<-- this tire is like --> / <-- that
front of bike
Old Jul 14, 2003 | 07:19 PM
CrAcKhEaD's Avatar
**** the picture didnt come out right sorry but the right tire is leaning like this --> / how can i adjust this? or y is it like that?
Old Jul 14, 2003 | 08:44 PM
jaycekarl10's Avatar
That is camber I believe and if you don't have adjustable upper A-arms you won't be able to cure the problem. Ask the guys at TBR products(preferred vendor at the vendors forums) to be sure. I've not heard of this condition when swapping 250r for 400ex spindles, but you may either need to find some 250r spindles, or some adjustable upper a-arms.
Old Jul 14, 2003 | 09:18 PM
CrAcKhEaD's Avatar
are they adjustable if the ball joints come off?
Old Jul 14, 2003 | 11:26 PM
No, I wouldn't advise trying to adjust it through the ball joints, usually aftermarket a-arms have adjustable heim joints located at the point where the arm meets the frame, if they are stock arms they cant be adjustable. The problem lies with the length of the upper arms. I believe the uppers on the 250 were longer than those on the 400 so in designing the spindle they made up the difference there. So where on the 400, the spindle is @ vertical, the 250's added length causes the upper location to be pushed further out causing the wheel to angle out. I'm no professional though, If others don't offer help ask the guys at TBR, They have the answers
Old Jul 15, 2003 | 12:04 AM
CrAcKhEaD's Avatar
alright thnx man~
Old Jul 16, 2003 | 12:45 AM
CrAcKhEaD's Avatar
ok i was able to adjust it about 1/2" in but its still not enough, its rideable now though. I asked TBR and they told me that i need aftermarket a-arms for them to work, but i talked to someone else and they told me that they should work with stockers???[img]i/expressions/face-icon-small-confused.gif[/img] if i bend the spindles in alittle will it make them weaker?
Old Jul 16, 2003 | 01:37 AM
JakalWarrior's Avatar
never looked at 400ex spindles, but is it possible to turn em upside down?
Old Jul 16, 2003 | 01:59 AM
DaBeechMan's Avatar
bending aluminum causes them to lose their structure. Do not bend them
Old Jul 16, 2003 | 02:12 AM
CrAcKhEaD's Avatar
if i turn them upside down the tie rods wont fit. I noticed that the 400ex also uses a seperate bracket to mount the calipers, if i put the 400ex bracket on mine will the caliper fit on the disk correctly? Im using it without the front brakes right now cause all i do around here is freestyle but i have a race in 2weeks so im gonna need the front brakes, any suggestions would be greatly appreciated. thnx~
2many2ride
Sep 27, 2015 04:35 AM
alex_2011
Jun 9, 2015 10:12 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
Mud_Runner
Dec 10, 1999 05:23 PM
