installed hotcam stage 2 in 400ex
Old Aug 6, 2003 | 01:31 AM
witti's Avatar
Default installed hotcam stage 2 in 400ex
First real test run on my friends ex after cam install. Noticed a huge diference on top end pull. Before the power was right at low end to mid range and it stoped, now it seems to kick in at mid range and wants to keep pulling.
good mod.
Does anyone know what the stock rev limiter is set at?
Old Aug 6, 2003 | 03:30 AM
RideRed81's Avatar
I am pretty sure it's 9300 RPM.
Old Aug 6, 2003 | 05:50 PM
yellowexracer's Avatar
Did he have a high compression piston in it and how much bottom did he loose?
Old Aug 6, 2003 | 07:51 PM
Ole's Avatar
Ole
Is the HRC cam similar to hotcams stage 2? If so I think I will go for the HRC. What other engine mods did your friend do?
Old Aug 7, 2003 | 12:22 AM
I think there close, i thought the HRC cam was alot more money, why would you want it over the hotcam?
Old Aug 7, 2003 | 01:15 AM
witti's Avatar
Other mods are fmf power bomb pipe and silencer, K&N filter with no lid. Thats it.
It did loose some low to mid range power, it seemed to move and add power to a higher rpm range.
High comp piston might help it out, but he said it is fine the way it is.
might be kind of bad for trail riding, lost some snap when luging engine. 13t sprocket could help in trails.
Old Aug 7, 2003 | 02:17 AM
cals400ex's Avatar
a 13 tooth sprocket? going down two sizes from stock is a pretty big difference when dealing with the front sprocket. has he ran against any other bikes? raptors, kfx's, z's etc?
Old Aug 8, 2003 | 01:09 AM
witti's Avatar
sory, I was thinking stock was 14t. Now I remember it is a 15t. So a 14t might help in trails. You might not need to dhange it at all, depends on riding style.
It was dead at the dunes when we rode, no one wanted to drag.
I raced him with my Z (runs very good).
He is not a very good rider and could not get a good holeshot. If we had a rolling start I would slowly pull away from him the whole race.
We traded and I ran right next to him until 5th gear and the Z started to pull away.
Before the cam install I would walk right away from him.
2many2ride
Sep 27, 2015 04:35 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
