400ex question...overheating
Old Aug 7, 2003 | 11:44 PM
MONSTERQUAD2020's Avatar
Default 400ex question...overheating
Hey, I plan on buying a 400ex soon and was wondering if a lot of you guys run air scoops on it...if so what kind do you think is good OMF or PRM...or is there another good brand? I dont want it to over heat but i dont want to do a lot of internal work like oil coolers and such. So if you could tell me what you guys do? Do any of you guys use those scoops? use a certain kind of oil? anything else? and how many of you guys actually have had overheating problems? Thanx a lot guys. I appreciate any input.
Old Aug 7, 2003 | 11:48 PM
yellowexracer's Avatar
I run OMF, fans in front of my oil cooler and mobil 1 synthetic with heavy clutch springs. The oil helped the most. You should check out the FST oild cooler kit, looks like it would help alot, I may get me one of those.
Old Aug 7, 2003 | 11:52 PM
thanx a lot, appreciate it
Old Aug 8, 2003 | 12:53 AM
Quadfather's Avatar
I never had any overheating problems. Ran it in the middle of summer, too. I did, however, put on some OMF scoops, and added an oversized oil reservoir, as well. I also run Mobil 1 synthetic, which, supposedly helps it run cooler. Running cooler means more power.
Old Aug 8, 2003 | 02:04 AM
StockRappy's Avatar
hahaha air cooled...gg
Old Aug 8, 2003 | 02:47 AM
ORANGE400exRACER's Avatar
Lick my nuts, stockrappy. You always talk sh*t. All this guys does is jacks off to kiddy **** and talks sh*t on ATVCONNECTION.COM all day long. There's a life out side of your computer. Have you ever seen daylight?
If you have any motor mods on your ex, then I would run a second oil cooler. Good oil and a bigger oil tank does help alot. I use LUCAS OIL STABLIZER with Castro GPS. I swear by this stuff.
Old Aug 8, 2003 | 03:55 AM
cals400ex's Avatar
[quote]
Text
LMAO yeah i agree, you may want to go to the yamaha forum and figure out why the raptors can't keep the carbs from falling off.
by the way, i also use mobil 1 with good success. i think overheating might occur riding is trails at really slow speeds where you are constantly on and off the clutch. from what i hear, the scoops won't cool the bike down much. you need to be moving for air to get through the scoops in the first place. most scoops are very similar. i would get whatever you can get the best deal on. good luck
Old Aug 8, 2003 | 11:21 AM
hutchies's Avatar
I have never had a problem with my ex overheating. The only time it gets pretty warm is when i am really reving the engine up. I don't have any scoops, oil coolers or any of that stuff. Just stock oil cooling system.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
