Bent valves??? the plot thickens
Old Aug 9, 2003 | 12:43 AM
djmac379's Avatar
Default Bent valves??? the plot thickens
i just took my top end off my 350x and found that the 2 exhaust valves are stuck open. there is no damage to the piston but i guess the piston must have clipped the valves and bent them. i have no idea why though. i checked the connecting rod bearing and that seems ok. the compression release has the cable disconnected. could that have rotated around wrong and held the valves open so they got slapped by the piston? i just replaced the clutch. could i have done something wrong when replacing the clutch. the valve timing is fine as well .............well i took the valves out of the head expecting to find them bent. they were stubborn and i had to pull and twist to get them thru the guides. next i put them in a drill to see how much they were bent and surprise there not! and once i got them out they slide back in and move great! whats the deal???????????any ideas would be appreciated .
Old Aug 9, 2003 | 01:05 AM
dork's Avatar
maybe you have an oil supply problem to the top end. how was the cam journals? the valves might be bent just a little, because there 's not much clearance between the stem and the valve guide so it wouldn't take much to stick. either that or the valve adj. was too tight. you definitely shouldn't have to struggle to get the valves out.
Old Aug 9, 2003 | 09:39 PM
djmac379's Avatar
thanks i will check it out
Old Aug 10, 2003 | 03:43 PM
Elrancho's Avatar
Siezed valves are kind of a classic overheated head problem. When sufficient heat builds up any oil in the valve guides cooks, litterally glueing the valves in an extended position. Luckily this may not involve any warping or bending. a cleaning may be all that's needed, and find what caused the overheating.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
