Drag race 300ex
Old Aug 20, 2003 | 09:29 AM
Dirtdog300ex's Avatar
Default Drag race 300ex
Has anyone ever tried to turn a 4wheeler into a drag racer.
I have a 300ex frame and im thinking of turning it into a drag on road racer at the local drag track.
This is what im thinking. 300ex frame, extending the swingarm, 500cc motor, soft flat track tires, keeping the 4wheeler as low as possible to the ground, making it as arodynamic as possible, removing the rear brake, removing any xtra metal as possible for weight, using an older air cooled 500cc motor. Does this sound crazy or fun? Any suggestions would help good or bad. Ive got 2 off road 300exs im not giving that up just something to do. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 20, 2003 | 10:12 AM
Other things also to think about (any suggestions would help)
anti sway for speed wobbling, gear ratio, how many inches for swing arm, and what type of exhaust?
Old Aug 20, 2003 | 11:18 AM
TheAvenger's Avatar
Sounds fun, not crazy! [img]i/expressions/face-icon-small-smile.gif[/img]
What type of 500cc engine did you have in mind? A single cylinder dirtbike engine or a multi-cylinder streetbike engine? Either way, if it's a drag track I'd go with straight pipes and no air filter (it's a paved track, right?).
As for the anti-sway, I wouldn't bother, I'd just remove the front shocks and replace them with steel tubing of some kind. That would make lowering it a lot easier. I'd say do the same on back, but the squat the shock would provide might get you off the line a little quicker. Just add a lowering strut, or, if you're going to extend the swing-arm just move the shock mount to lower it.
As for the swing-arm and gearing, I don't really know. At first I would build a wheelie bar and see if that works before extending the swing-arm. The gearing is something you'd have to play with to see what works.
Good luck with it! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 20, 2003 | 11:57 AM
Yea its an 1/8 of a mile asphault drag strip. Id like to go with a single cylinder only because i know how to work on them and im not sure if anything else would fit in that small of a frame.
The only reason i was wondering about the anti sway was because im not sure of what kinda speed id hit and would worry about speed wobbling been there done that its not fun.
Ive got a lowering bracket for the front shocks but taking them off could reduce weight as well.
Id probably be able to run with the pro stock cars and maybe some of the stock smaller street bikes but not real sure i might get crushed lol
Thanks
Old Aug 20, 2003 | 12:23 PM
jed250's Avatar
I suggest putting in a Ski-Doo engine. Ski-Doos/snowmobiles go faster than fourwheelers as it is and they are a heck of a lot heavier. Putting a ski-doo engine in your ATV will make it rule on the track. I suggest putting in an 800cc twin Ski-Doo engine. All Ski-Doo engines (except newer models from 2004) are 2-stroke, so you have approximately 1600cc's of power (a little less). But you would use the belt and pulley system that the ski-doo uses. Put the drive pulley on where the rear sprocket would go. Hit the gas and you'll fly. Be careful not to pull a wheelie right over yourself.
Forget the 800cc engine. Look for a 500cc. 800cc is way too much. I read in dirtwheels that a guy put a polaris snowmobile 600 triple into his ATV.
Old Aug 20, 2003 | 01:24 PM
Thats cool dont want to kill myself lol.
Thanks for the info
Old Aug 20, 2003 | 03:02 PM
manual's Avatar
i was looking on ebay a while back, some guy had a 600cc blaster extended frame w/ extended swing arm, was pulling the quater mile at 114 MPH at like 11.3 seconds
not sure all he did to it, but ended up going for like $900 + $400 for shipping
Old Aug 20, 2003 | 03:21 PM
Did it say what kind of motor the 600cc was? What it was out of?
Old Aug 20, 2003 | 07:32 PM
manual's Avatar
not quite sure this was about 2 months ago, GXR or GZ or soemthing like that was in the title but i didnt pay mutch attention
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Sep 1, 2015 01:45 AM
