Piston Compression (400ex)
Old Aug 25, 2003 | 02:24 PM
STILLinFRONT's Avatar
Default Piston Compression (400ex)
Has anybody checked their compression? What is the spec. for good rings (psi)?
I am going to check mine tonight. I have put 2 hard years on my stock motor. I have raced MX a little and I did alot of drag racing at Silver Lake. I have decent low-end power, but I lost my top-end. I susepect my motor is getting old. When I adjusted the valves, it was easy to turn over with the wrench. The head gasket is fine, it does burn a small amount of oil.
Old Aug 25, 2003 | 02:33 PM
sickmojave's Avatar
does it smoke? you may have blown a head gasket. I maybe wrong but I think anything over about 120 psi is good, but I'm just guessing here. maybe someone else will have the info you need. Good Luck [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 25, 2003 | 07:16 PM
whatwasthat's Avatar
100-128 psi is acceptable
Old Aug 26, 2003 | 01:38 PM
Does anybody know the spec?
100-128psi is only acceptable for 2 strokes.
I measured mine yesterday and got 165psi! This is a good number. I heard new is like 175?????
After I was done, I calibrated my tester at work, it is only off by 1 psi.
This weeekend I will get the chance to test an '03 with like 10 hours on it. I will report the results.
Old Aug 26, 2003 | 02:22 PM
sickmojave's Avatar
I can't find it in the Honda sevice manual. good luck with your ride this weekend.
Old Aug 26, 2003 | 08:43 PM
page 5 (x) of my shop manual states "cylinder compression: 100-128 psi ( 686-883 kPa)
Old Aug 26, 2003 | 09:48 PM
sickmojave's Avatar
I found it in the honda sevice manual on page 7-1 and it says the same thing you did"cylinder compression: 100-128 psi ( 686-883 kPa)
Old Aug 27, 2003 | 05:44 AM
RideRed81's Avatar
I would rebuild it if you had been using it for MX, chances are it's due for a fresh topend.
exmotocrosser
Sep 13, 2019 06:12 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
