Old 350trx 4x4 fuse question
Old Sep 2, 2003 | 12:57 PM
chuckinnc's Avatar
Default Old 350trx 4x4 fuse question
My fan & oil light quit working so I think it maybe be a fuse, I dont have a service manual for this old 1986 tank so can anyone help with
the location of fuse or fuses ?
Old Sep 2, 2003 | 09:51 PM
devocorky's Avatar
The fuse block on mine is located in the rear compartment right beside the battery. You cant miss it.
Old Sep 3, 2003 | 01:42 PM
gravedigger's Avatar
Something else to look for is to pull off your cover and take a look at the wiring behind the key/ignition system. I had the same problem and found that i had a broken wire on the back of my ignition. You may be right about the fuse but take a look at the wires if you do not find a bad fuse. And yes the fuse box is easy to find. Right in the back becide the battery just pull off the little black cover and they should be right there.
Old Sep 4, 2003 | 08:00 AM
devocorky's Avatar
Hey gravedigger, how do you like your 350?
Old Sep 4, 2003 | 11:48 AM
I got the name from the bike... it is a tank... rides rough.. handling is not fantastic... slow top speed.... but it will actually outrun lots of the new honda 400's on a straight away for the first little while anyway. Good power for pulling stuff around the yard, and it will go through a lot more then i first thought it would. I bought mine in pretty rough shape. I have had to do the top end of the engine, redo my carb, and play with my brakes to get them to work. I wish i could find some plastic for it though, I have white puck board where the rear fenders should be... :-) all in all I guess it does the job. I intend to buy something new this spring... actually have not decided between Honda, Yamaha, and yes maybe even Polaris...... I ride with a guy that has a new 700 sportsman.. I have seen him go through stuff that i thought you could not make it through.. even float down a creek/stream and come out again no slipping or sputtering... I was impressed...
My old girl had some kinks to work out.. if you had of asked 1 month ago i would have said biggest piece of crap i have ever owned... but i have gotten a couple of good rides on her since so i will probibly keep it as a second quad when the kids and I go out.. give them the auto ??(when i get it) and I will take gravedigger... Lots of fun... and you really dont care if you scratch up the sides... make a good beater.
Old Sep 4, 2003 | 01:05 PM
devocorky's Avatar
Thanks for the reply, any pics of the old bitch? ( the 4-wheeler that is...)
Old Sep 4, 2003 | 02:44 PM
LOL... not yet... its like the old joke about sleeping with a fat chick is like riding a moped... you do it when you have to and it gets the job done but you dont what your friends to see.... :-) actually I have a roll of film that we took going through some mud a couple weeks ago.. I will get them developed and see if anything turned out.... and I will let you know.
1ArmBandit
55
Oct 14, 2015 09:03 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
