4ooex head gasket
Old Sep 8, 2003 | 01:17 AM
tuggle's Avatar
Default 4ooex head gasket
resently i have installed a 416 piston and had my head sheved. since this though my head gasket keeps blowing. does anyone know what could be causing this?
Old Sep 9, 2003 | 06:27 PM
tuggle's Avatar
thanks for your help. i'm goin to pull it off tonight and check it out and i guess more then likely get me some new head bolts somewhere. any suggestions on which ones to get or what size to get?
Old Sep 9, 2003 | 11:24 PM
tprender's Avatar
I went though 3 head gaskets before we found out that the stock studs from Honda will stregth from the high compression and head. After I went and got a set of the larger head bolts from TC Racing I have not had any problems. Most people think that the gasket is bad, but it is the stock bolts from What Tom Carlson told me. He said that the bolts are weak and the Studs go into the head not the cast like on other engines and this cases the threads to pull out of the metal in the head with higher compresion. The larger bolts solved my problem.
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
