jetting problem
128 was the biggest the kit came w/ and im running a 124 right now... but i have another problem(switched the needle e clip up to groove #4, seeing if that would fix it) and i adjusted the screw which i thought was fuel mixter... but it wasnt-think i might have been a bleed line.... so i hooked up my gas tank and turned it on and leaked... so i tighted the screw as far as it could go... and its still leaking.... any ideas? quad wotn start up either
hey, it does run noq but when i let off the gas it will die, and it is running rich my brother and my friend really dont know anything about quads but they said if i screwed ou the fuel mixture(didnt touch it) it would not run rich and it wouldnt die when i let off the gas.... true or false?
#16
keep going down on your main untill she stops sputtering. simple and easy fix. Plus shel be alot faster[img]i/expressions/face-icon-small-wink.gif[/img] And ummm Im pritty positive that if you screw OUT the air screw it will be even richer. If you need to know how to set that just ask me.....
#17
Yeah you kinda sound like a big retard... like you dont know what you are doing at all.... i think you should go read the damn manual stupid kid..... or get a better quad yours sounds like a POS. I doubt you could get 1500 for you quad....
#18
hey, welcome to the forum you @$$, that's a good way to start out with your first post ROOK! at least he is tryin to learn how to work on his machine and not just sending it to the dealer mechanic. do us all a favor and leave this forum.[img]i/expressions/face-icon-small-mad.gif[/img]
#19
ok i was running to rich, has a lot of more get up and go now,but bogs when i press the throttle hard(kinda sputters but works good still), any solutions to that
Follow the above advice on dropping the main jet size till the bog goes away. did you clean the filter?
Also after (not b4) you get the current bog problem fixed with the right size main then try dropping the needle clip down one more (raising the needle) and see what that does from 1/4 to 3/4 throttle. If it runs better leave it there if its worse or bogs raise it back etc.
Sounds like your allmost done [img]i/expressions/face-icon-small-smile.gif[/img]
#20
