Quad pulls to the right!!!!!!!!!
Old Jun 5, 2000 | 06:03 PM
Hondapride's Avatar
My bike pulls to the right a little
does anyone know how to fix this. I think you have to adjust the A-arms right??
Old Jun 5, 2000 | 06:52 PM
2punksdad's Avatar
tire pressure may be the problem........check it first.
Old Jun 5, 2000 | 09:50 PM
hot_shoe_cv's Avatar
If unequal tire pressure isn't the problem, check the entire alignment specs; caster, cammber, toe-in, bent A-frame, or worst case, bent frame. The last one is what I had to deal with after a head- on with a dirt bike...mucho dinero!
Old Jun 5, 2000 | 10:02 PM
hondatrx300ex's Avatar
check what they've said then point your bars straight then get in front of your quad and see if your tires are straight.....if they aren't you can adjust this with the tierods.....just a guess.
Old Jun 5, 2000 | 10:54 PM
BigRed450's Avatar
Your problem is most likely the tire alignment, which is easy to set. Look under the topic Tire Alignment for the procedure.
Jeff
Old Jun 6, 2000 | 11:07 AM
Tim1's Avatar
Hit the button on the handle bar which puts it in 2wd mode it makes a major steering improvment.
Old Jun 6, 2000 | 04:18 PM
Hondapride's Avatar
Ok I put my bars as strait as possible and can see that the left tire (right when you are sitting on it)is pointing a little farther out than the other one. So now what do I do
Old Jun 6, 2000 | 07:42 PM
hondapride: what do you ride? well anyways its pretty easy just loosen the two nuts that lock down on your tie rod ends......then just turn the tie rod and it should pull the wheel in (or out whichever way you turn it).....get in front of the quad and try to make both of them straight as possible.....then just tighten the nut back down on the tierod end..then take it for a ride....thats about it..... later
Old Jun 6, 2000 | 07:48 PM
let me know how it turns out
Old Jun 6, 2000 | 09:41 PM
Hondapride's Avatar
I ride a 1998 Honda Recon
thanks a lot for the help
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
tweeder
Jul 5, 2015 01:57 PM
D-Hagz
Jul 4, 2015 02:19 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
