416build up?
Old Sep 24, 2003 | 02:27 PM
hooka's Avatar
Default 416build up?
whats up everyone iam trying to do a 416 igot a je piston ? on the piston there is arrow does this point to the frount of the bike (exhaust side) an also there is a N on the top ring does this face up. also running a hotcam stg 2 do u adjust valves at factory spec or what any other info on this buildup would bea great help thanks alot
Old Sep 24, 2003 | 05:57 PM
boogerbub's Avatar
Yes, the arrow points to the exhaust side. If in doubt, look at the valve cut-outs on the top of the piston and size them up with the valves in the head (exhaust valves are bigger). I am nearly 100% on letters facing upwards on the rings. Did they come with a little sheet of paper with directions? If not, I'd face them up. On the valves, I believe the suggested clearances from Honda are .005 or .006, but call a local shop to find out for sure. Whatever it is, I always like to set them just a tad bit tighter. So if Honda says .006, then I would go .005. Probably doesn't make a difference, I'm just kinda used to a tight fit[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 28, 2003 | 10:53 AM
hooka's Avatar
thanks 4the info .it came with papers but it had info on gap spec only nothing else . its running now an it is a lot diff. 416 , 11.1, stag 2 hotcam port n polish ,yousi full , k&n, steelflex, 180mn 42 pilot c-12 RUN FAST AN HARD
