250r swingarm
Old Oct 17, 2003 | 11:47 PM
toyaddict's Avatar
Default 250r swingarm
Does anyone know if the later model aluminum swingarms will fit on an 85 atc 250r, and if so can you use the same bearing carrier or do you have to change the carrier,axle and all? Any help appreciated.
Old Oct 18, 2003 | 07:44 AM
elsancho's Avatar
i dont think so... the atc 250r's have a narrower bearing carrier housein. as well the swingarm bolt tube for the aluminum swingarms is a single tube wherass pre '88 used two tubes with a spacer in between. i also beleive that the pivot tube complete is narrower
Old Oct 18, 2003 | 03:43 PM
havinnoj's Avatar
The '88-'89 arms are an inch shorter. Also you cannot use the rear engine mount if u tryed an 88-89 arm on an 86-87.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
