Carb set-up
Old Nov 9, 2003 | 11:30 PM
fastasyoucango's Avatar
Default Carb set-up
I was wondering what jet to use in my carb after I build up my 400ex? Mods will be 416cc JE 11:1 piston, Hot Cams stage 1 cam, ported and polished head with stock valves, K&N filter and a White Bros E-series pipe. I'll be getting like 5 jets in the kit I ordered. I think the biggest is a 170. What would you guys try first?
Old Nov 10, 2003 | 02:40 AM
XR650Warrior's Avatar
Default Carb set-up
first bolt your egt meter on and read the display, then there is no question about how to jet
Old Nov 10, 2003 | 03:23 AM
440EX026's Avatar
Default Carb set-up
Start out big then reduce until any bog goes away and do a plug check, but dont forget the needle and pilot jets either.
Old Nov 10, 2003 | 07:24 AM
Default Carb set-up
If it bogs at off idle, then it needs a pilot screw adjustment, right? Do you think I might have to step up to a bigger carb? I hope not, they're kinda expensive.
Old Nov 10, 2003 | 10:34 PM
TractorPacker's Avatar
Do you have a balloon?
Default Carb set-up
Spend the $450 for an FCR 39mm, it will make you regear. I can't believe what that carb did.
With the 416 modded as listed you will probably run a 165 main and maybe a 40 pilot.
Old Nov 11, 2003 | 01:45 AM
cals400ex's Avatar
Default Carb set-up
a lot will have to depend on the weather your riding in, the elevation your at, running an airbox lid or not, etc. on average i would say around a 158 to a 162. now, these are keihin jets, not dynojets. i run a 45 pilot jet and my needle i change depending on temp. most of the time its on the 4th position.
Old Nov 11, 2003 | 09:25 AM
Default Carb set-up
The kit I ordered is a Dynojet kit. Are they no good? What's the difference between them and Keihin?
Old Nov 11, 2003 | 01:06 PM
cals400ex's Avatar
Default Carb set-up
well i don't use dynojets. we have a keihin carb. dynojets have a different numbering pattern. make sure you know this. for example, a 150 keihin is NOT a 150 dynojet. the dynojets have a little different taper to them. this kit will come with a needle. you are suppose to use their needle if you use their mainjets. from what i hear, it is tougher to fine tune your bike with the dynojets because of the jets they make. for example, with the keihins you can get a 150, 152, 155, 158, 160, etc. with the dynojets, the numbers are more spaced out. many people use this kit so i am not saying its bad. personally, i would not use it because i can buy individual keihin jets for a cheaper price. but since you have it ordered already, its fine. also, disreguard my first post. the mainjet numbers i told you were for keihin jets. i am sure you will be somewhere in the ball park of these numbers. however, i have never used them so i can not tell you for sure. it will come with directions. i would just do a few plug chops and see what the plug looks like after some full throttle runs. jetting is trial and error. good luck
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
