86 250r wont start please help
Old Nov 13, 2003 | 07:57 PM
660rappy's Avatar
Default 86 250r wont start please help
ok i was out at glamis last weekend and my bike was running fine i went for a ride stoped for a break and bike would not start again put in a new spark plug checked wire connections and now there is no spark.
My brother has the same bike so we changed out some parts the cdi box the ignition coil and it still has weak or no spark. what could be wrong.
its a 1986 250r
Old Nov 13, 2003 | 08:05 PM
Billsner's Avatar
sometimes , my sparkplug wire comes loose at the cap, check that.
Old Nov 13, 2003 | 08:08 PM
660rappy's Avatar
did that already thanks for the reply any other ideas
Old Nov 13, 2003 | 08:10 PM
honda4fun's Avatar
If Im not mistaken there is a magnet inside where the coil is you need to make sure it is the proper distance between the magnet and the outer coil and make sure the surface of the coil is clean between the magnet and coil.there is a adjustment in there with two bolts.Also trace the wires coming out of the coil all the way to see if maybe they might be fraid somewhere. Good luck.
Old Nov 13, 2003 | 08:17 PM
660rappy's Avatar
i dont think that is it because i put my coil on my brothers bike and it started right up
Old Nov 14, 2003 | 01:56 AM
660rappy's Avatar
macentyre your from running springs my uncle lives there and i am going up there this weekend any ways stop by the fireside sat night say whats up thanks for the help
Old Nov 14, 2003 | 02:16 AM
macentyre's Avatar
I would totally come say whazzzzupp...but I'll be in Big Bear all day....
Sorry)=
Mac
Old Nov 14, 2003 | 09:22 AM
Chawness's Avatar
If its not the coil and its not the CDI, try using his plug wire and cap. Pull the plastic off and check all the connections. If it is the stator the bike will do some mighty funny things like run great then not run at all, off and on etc. What year 250R does your brother have, his CDI box may not work on yours.
You did take the flywheel and stator off the bike right? if not it could be a sheared key-way too. Sounds like a stator problem to me, been there done that................
Old Nov 14, 2003 | 07:57 PM
fivel250rman's Avatar
You changed some electrical components but did you check the ground that comes from the wiring harness and bolts to the left side of the frame near the upper radiator mount.Just a thought.
Old Nov 16, 2003 | 01:22 AM
CrAcKhEaD's Avatar
Sounds like good'ol PMS to me. I get that all the time with my R, one minute it will be running cherry next minute its not getting spark?! I hate when it does that usually ill just put her away and she'll fire right up next morning.
joe blo2
Jun 7, 2015 10:54 AM
1000gade
May 27, 2015 12:37 PM
bigg_fatt_monn
Jun 16, 2000 09:41 PM
rking85
May 20, 2000 11:01 PM
250rCanCan
Aug 17, 1999 11:58 PM
