lrd 460 kit
Old Nov 15, 2003 | 01:40 AM
yellow426's Avatar
Default lrd 460 kit
anyone know if the lrd 460 kit would beable to keep up with the new trx450r ?what would be involved in having a 460 kit but in ? do you need to change your rod our split the case.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Nov 15, 2003 | 01:00 PM
cals400ex's Avatar
Default lrd 460 kit
changing the rod will be needed. splitting the case for this will also be needed. you will probally need work to the crank too. it will cost a lot but it should be fast. personally, i don't think the new 450 is going to be that fast. just my opinion. its a honda, its not going to do 100 or anything. it will handle and be reliable. i assume you will need a lot less work than a 460 to beat the new bike. just my opinion, they are not out yet!!
Old Nov 15, 2003 | 01:49 PM
wildchild660R's Avatar
Default lrd 460 kit
I have had experiance racing a LRD460 at Florence, Oregon and to tell you the honest truth I wasnt very Impressed. My piped jetted and geared raptor beat it by about 2 bikes and I was assuming Id get beat pretty good. I think you could make a 416 run better or very close to what they do but thats just my opinion.
Old Nov 16, 2003 | 02:18 AM
yellow426's Avatar
Default lrd 460 kit
thanks for your input on lrds 460 kit .most likely going with a 416 kit and a stage 2 cam do you know what the piston size is?
Old Nov 16, 2003 | 02:27 AM
Ds650RaCeR's Avatar
Default lrd 460 kit
440 all tha way baby!!!my wiseco 440 is only 2 bikes behind my alky stage 1 ds...11:1 high comp piston,39mm alky carb,head work,hot cam stage 2 cams..but now since i have made my ds a stage 3 it comes no where close...but i gear whatever you get down any if you are going to be racing the flat's b/c you will loose MAJOR top end..i did..
Old Nov 16, 2003 | 02:45 AM
cals400ex's Avatar
Default lrd 460 kit
the piston size on a 416 is 87mm. i would recommend a je or ross 10.8 comression piston. with this, you will still be able to run on pump gas. if you want to run race fuel, you can go to a higher compression. i run a 406 (86mm piston) with a stage 2 cam and it runs great. you won't be disappointed. i wasn't sure what to expect. it definately made more of a difference than my pipe, filter, and jetting. no, it won't smoke banshees and other larger cc quads, but it will run good and my reliability has been great.
Old Nov 17, 2003 | 12:30 AM
speeddmn's Avatar
Default lrd 460 kit
Yellow426 if you want a fast 400ex send it to KENZ in mesa,az. My bike will outrun alot of raptors with a 686 kit in it and it totally smokes piped bikes of all sizes including banshees and yfz 450's.
Old Nov 17, 2003 | 12:34 PM
cals400ex's Avatar
Default lrd 460 kit
what all do you have done??????? a freaking turbo!!
Old Nov 18, 2003 | 01:07 AM
speeddmn's Avatar
Default lrd 460 kit
cals400ex no I don't have a turbo, I've got a great running 440 kit.
Old Nov 18, 2003 | 03:06 AM
440EX026's Avatar
Default lrd 460 kit
I have a feeling theres more going on here than a piston, sleeve and some gaskets LMAO [img]i/expressions/face-icon-small-smile.gif[/img]
