Pipe Glowing Red
Old Dec 1, 2003 | 10:41 PM
TheQuadSport230's Avatar
Default Pipe Glowing Red
Hi, I was wondering about that. I just rode my 300ex about 2 hours ago in the snow making it rev a lot. It's a 94 with the mods below. It was about -10 celsius degrees outside. It was revving a lot and a lot in the deep snow [img]i/expressions/face-icon-small-smile.gif[/img] . The exhaust them became red. A warrior was with me and it didn't happen. He's stock and he's still having is summer's jets in his. I just rejetted mine earlier today. I was jetted for about 15 celsius degrees with a 124 dynojet. When the exhaust was glowing, there was a 128 in it. I just added a 130.
Thanks a lot
Old Dec 2, 2003 | 11:46 AM
action450s's Avatar
Running lean??? Check the plug colour.
Old Dec 2, 2003 | 01:09 PM
sickmojave's Avatar
I agree it sounds like it maybe lean. you may need to rejet for winter.
Old Dec 2, 2003 | 01:57 PM
RINCON's Avatar
totally normal. At least it is for the 450's. (foreman) Especially in the snow.
Old Dec 2, 2003 | 08:12 PM
warriorgod's Avatar
It's definately lean, does your head pipe turn red while your sitting there and reving the engine?
Old Dec 2, 2003 | 09:15 PM
dork's Avatar
thats probably normal as long as it doesn't seem to run lean. let any fourstroke idle for a bit in the dark and the headpipe will probably start to glow at the head. and if you're working it hard in the snow with little airflow, then you may see it then too. i had a wolverine that was stock and jetted correctly that would do it, my yz does it. you even went richer on the main so if anything your jetting is richer.
Old Dec 2, 2003 | 10:18 PM
Yeah I know it's running lean. I was running a 124 for under 20 celsius degrees. Tried 128 yesterday. Tried 130 1 hour ago. It's still become red after being stuck in snow for 30 seconds. My last hope is my 135 jet. Would it be okay or is it just normal in the winter?
Old Dec 4, 2003 | 06:01 PM
Anybody?
Old Dec 4, 2003 | 06:41 PM
WISTECH's Avatar
Dont worry about it . Under medium load and high rpm all of my hondas were glowing red when doing countless doughnuts on ponds and lakes.
Old Dec 5, 2003 | 08:01 PM
cals400ex's Avatar
hold on here. you might not be lean on the mainjet. take your bike out and floor it though all of the gears. it is best to do this at night so youcan see the headers glow. just floor it all the way though the gears, and have someone look at your headers when it is pinned. if it glows at full throttle, your probally lean on the mainjet. however, you could be lean on the fuel skrew/pilot jet or the needle. if its glows at idle, turn your fuel skrew out some. if they glow at 1/8 throttle to 3/4 throttle, move the clip on the needle down one position.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
Bigtwin700
Sep 9, 2015 09:32 AM
