6-speed tranny for 400EX???
the power a 400ex has nothing to do with whether or not it can pull 6th gear. You can give it 50 gears, and if geared properly it will pull it without a problem.
But no, its impossible to put a 6th gear in a 400ex tranny. The engine wasnt engineered to do that. Thus, not enough room
I'm sure that we have all looked for another gear (because we want more speed), but trust me there would have to be a huge run in order for you to even try putting it in 6th gear. I don't even know why this thread exists you can't even put a 6th gear in it. But if you want to know what it would be like to have another gear, put a 16 tooth front sprocket on and tell me then that you have enough power to pull it.
#16
Over-drive is just that. Over (as in higher) than the drive gear (which is 1:1) So anything higher than 1:1 is over-drive. Even .99:1 is an overdrive.
A 6 speed could be helpful because it gives a slightly larger arrangement of gears. Even if the 6th gear isn't higher than the current 5th gear on the 400. You can have more gears in between what you have now, sorta.
#18
Originally posted by: cals400ex
i thought i read something about this on a different bike. if i remember correctly, neutral would need to be removed though. i can't remember where i saw this or even if it was done.
