300ex black box
Old Jan 19, 2004 | 12:31 AM
300racer's Avatar
Default 300ex black box
what would removing the factory limiter do to it? how much more top speed would it give.and should i lighten my flywheel. allwork would be from profab atv
Old Jan 19, 2004 | 08:55 AM
kwackermann's Avatar
Couldn't tell ya- and probably not.........
Old Jan 19, 2004 | 09:39 AM
dzzy's Avatar
what would removing the factory limiter do to it? For one thing, make it a lot more likely to over rev, bend your valves, break your guides and in general make a mess of your head.
Old Jan 19, 2004 | 12:00 PM
300racer's Avatar
oh,does not sound good at all!!! what about lightned flywheel
Old Jan 19, 2004 | 09:10 PM
dzzy's Avatar
Would allow it to rev a bit faster, and reduce the flywheel effect, or engine breaking when you let off on the throttle. It could also throw your crankshaft out of balance, possibly increasing vibration. That's just a guess on my part 300racer, maybe somebody else on this forum has actually done it.
Old Jan 19, 2004 | 09:25 PM
300racer's Avatar
not good,would it pull alot harder or just a lil bit through the gears
Old Jan 19, 2004 | 09:50 PM
manual's Avatar
acuttly it may increase top speed.... since the rev limiter stops it from reving any farther(acting as a governer), and if you could get the torque to pull it to max it out, it should be pulling the wheels faster increasing top end(if that makes sense). as far as relability im not sure because i havent ever used one, but quite a few people have
Old Jan 19, 2004 | 10:09 PM
300racer's Avatar
cool, but will it gove more low end i think it should because less weight to move
Old Jan 19, 2004 | 11:13 PM
Eric250EX's Avatar
i think all of dzzy's pints are right and the rev limiter is there for a reason but we may be wrong
Old Jan 20, 2004 | 12:24 AM
300racer's Avatar
well i just figure they must be taken them out for a reason you know?
