TraxLok conversion on 2001 Honda Foreman 450 ES
Would someone please explain how I have to do the electrical connection on the front 2002 differential I am installing on my 2001 Honda 450 ES to do the TRAXLOK CONVERSION?
I have 3 electrical harnesses coming out of the 2002 front differential:
Harness #1) 3 wires (black, green, red) going out of what appears to be a sensor in the differential itself.
Harness #2) 3 wires (black, green, red) going out of what appears to be a sensor in the TraxLok mechanism.
Harness #3) 2 white wires (with yellow and red) going out of the TraxLok mechanism.
Regards, Sergio A Raynal
To Howie, BigBugs, Stomper, UniBog and all the people that took interest on this post....THANKS A LOT!!!!!
I got my TraxLok up and running last night and it works fantastic. You can hardly hear a click when it engages or disengages, no matter the speed, ( I'll just be careful not to switch when spinning tires).
The only catch to this mod is that the speed sensors info is not processed anywhere to avoid damage when spinning. If someone knows what 2002+ part to buy and how to connect it to the two sensors I would apreciate the info.
One last thing. I bought a 2002+ display panel as well to get the fourth (TraxLok) indicator. The hookup harness is the same as 2001 except for an additional loose wire, Does anyone know how to do this set up?
Once again, thanks to you all for the time you have taken to help me on this matter.
Regards, Sergio
Regards, Sergio
Jul 22, 2015 05:00 AM
TLC
Jul 11, 2015 02:28 AM
