200x rear brake caliper
Old Jan 21, 2004 | 11:17 PM
jkgrybil's Avatar
Default 200x rear brake caliper
Does anyone know if a rear brake caliper from an 85 200x fit a 1986 200x three wheeler?
Old Jan 22, 2004 | 01:49 AM
KNOWSALOT's Avatar
The Facility
Yes. It's the same caliper, although the bracket is different. If your bracket is OK, then the caliper will be fine, but if you need the bracket too...you have to have the bracket from the 1985 model.
Old Jan 22, 2004 | 10:46 PM
jkgrybil's Avatar
So if I use the 85 caliper, I will need the 85 bracket or can I use my bracket off my 86 for the 85 caliper?
Thanks for your help
Old Jan 23, 2004 | 12:42 AM
KNOWSALOT's Avatar
The Facility
Sorry about the confusing reply. I see it as well now.
If the bracket on your 1986 model is OK...then the caliper is all you need from the 1985 model and it will work.
Old Jan 23, 2004 | 09:39 PM
jkgrybil's Avatar
Thanks
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
